Discussion topic: On demand
This message was authored by Emmappppppp This message was authored by: Emmappppppp
On demand
I can't record on demand I can't do either as or hd
I need a reliable number to get to speak to an actual person please
Locked
This message was authored by Quoman7 This message was authored by: Quoman7
Re: On demand
Hi @Emmappppppp  Try downloading in SD as you may not have the HD add on subscription?
Emmappppppp
Re: On demand
I have tried sd
ive rebooted box and internet I've tried to upgrade
I've rang sky 10 times today alone it's very frustrating
This message was authored by bob1234 This message was authored by: bob1234
Re: On demand
@Emmappppppp I have escalated this to Sky and hopefully they will come back to you, Private message or email, and be able to sort something out for you. Look for a blue blob bottom right of your screen.
Re: On demand
hi @Emmappppppp I am afraid there can be a problem for some new customers trying to download on demand etc.
If you are getting that problem then unfortunately yopu probably do need to get them to update the systems/ refresh your card etc.
I believe the customer service should be back on calls.
Emmappppppp
Re: On demand
Hi I'm not a new customer and advisor already sent settings but still nothing he told me to wait 24 hrs which I did and it's still won't work
Emmappppppp
Re: On demand
Thank you for your help
Locked
