This discussion topic is read only Discussion topic: Not able to record from TV Guide
This message was authored by: DeeBee33
My Sky+ box currently unable to register record when button pressed in TV Guide.  It does work if programme located through Search capability.  Any help appreciated as some programmes are impossible to find using search (upcoming F1 GP being a case in point, which I cannot locate using Search, but am unable to set to record this coming weekend from the TV Guide).
Locked
Re: Not able to record from TV Guide
Try a planner rebuild:
Press Services on your remote
Select Help
Select Sky+ Rebuild
This should take no longer than 10 minutes, don't do it if you are recording or due to start recording something.
Locked
