3
This discussion topic is read only This discussion topic has been answered Discussion topic: No signal tried everything . Able to see some channels
This message was authored by: Myi
No signal for 3 days!
Tried every thing reboot etc.
This message was authored by: GD1 Answer
Re: No signal tried everything . Able to see some channels
If you can view some channels and not others and your getting a No Satellite signal then it would suggest an issue with your box.  I would give Sky a call, you can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Locked
Which Sky System do you have?
1. Sky+ (Sky+ Forum)
2. Sky Q (Sky Q Forum)
3. Sky Glass/Sky Streaming Puck (Sky Glass Forum)
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Avatar for Myi
Many thanks all responses.
Locked
