6
Discussion topic: No satellite signal to one Sky box (other tv working)
This message was authored by johnnynujazz This message was authored by: johnnynujazz
I have checked cable connections at back of sky box - not loose.
I have checked signal strength as instructions:
Input 1 - Lock Indicator  - Not Locked
Input 1 Network ID - Transport system - NULL
Telephone Line Connected - CONNECTED
As we are getting Sky supply to one TV could it be one of the cables from the Sky dish?
This message was authored by Annie+UK This message was authored by: Annie+UK Answer
Re: No satellite signal to one Sky box (other tv working)
See my FAQ
Note: I am Neurodivergent, Hardware: Sky+HD LG UHD TV Xbox Series X Amazon Fire HD
My Sky Frequently Asked Questions:PlusGlass / Stream
Locked
It could br the cable/dish(LNB)/sky box(Tuner)
Try swapping the two cables around at the box end to see if the issue moves to Input 2
johnnynujazz
Hi thanks for reply
when I go to signal it only says I put 1 and there is no input 2 listed. I thought this was odd as says check both
If you have two dish cables then check single feed is off in the hidden menu
johnnynujazz
Hi
sorry what is the "hidden menu" please and where do I find that?
johnnynujazz
Hi
@Annie+UK
See my FAQ
Locked
