This discussion topic is read only Discussion topic: My tv listings on Documentaries are not showing.. lots of them are missing.
This message was authored by: JJ987654321
Can anyone please help me and give me some instructions on how to fix my documentaries tv listings.. loads of channels are not listing their programmes. I've tried to contact SKY with no luck ( it's 22:26) and I'm really frustrated as my tv has been like this for a few weeks now 🙄 .. I only watch the documentary channels so it's really problematic.. I'm sure one of you lovely people will have a solution xx
Locked
Re: My tv listings on Documentaries are not showing.. lots of them are missing.
hi @JJ987654321
Can I suggest a restart your main SKY Q box :
 Use the remote to place it into standby mode
 Then remove the power to it (either switch off at mains or remove the power plug)
 Wait at least 30s
 Then re-apply the power & wait for it to fully restart - this may take a few minutes.
If you have minis it might be worth doing the same on those after the main box is working
Avatar for JJ987654321
Hi, I've already tried the on and off thing and it hasn't worked. I've seen another post about checking to see if I'm connected to 2 satellites but I can't seem to find where I can see that info on my sky box.
Noticing a similar problem this morning.
The Sky Documentary and Sky Comedy channels listings had a number of blanks in the tv guide from tomorrow mornings listings.
Just done a main box power off reboot for a few minutes and it is resolved.
Locked
