This discussion topic is read only Discussion topic: Multi box not showing green light
This message was authored by: Lala2089
Hi, multibox is not showing green light. Tried all reset options with no luck
Locked
Re: Multi box not showing green light
Hi @Lala2089
Work through the following link.
If you cannot solve your issue you should have an option to replace the box
https://www.sky.com/help/diagnostics/sky-q-stuck-on-standby/check-your-remote
Locked
