This discussion topic is read only Discussion topic: Mini box not working after reset
This message was authored by: Carlyb65
One of my mini boxes isn't working the TV is showing no signal, it is on the right input and sky remote is working. When I switch off the box for 30 secs and then switch on the sky "hello" message appears as though it's initialising but after a couple of minutes it then goes blank. The main box and my other mini box are working with no problems. I have tried resetting the main box and then the mini box but still the same thing happens
Locked
Re: Mini box not working after reset
hi @Carlyb65
May I possibly suggest a full reset of your remote control
Press & hold 7 & 9 until the red led flashes 4 times.
When it has reset it will be in infrared mode so needs line of sight of the mini - hopefully the Power on / Home or SKY buttons will activate the mini OK
If it does then you will then need to rep-pair it with the mini pressing 1 & 3 together & follow the on screen instructions
This message was authored by: Willie+B
Did have a same problem with my Sky minibox and thanks to your kind suggestion of resetting the remote control, I was able to "waken up" the minibox which was stuck on standby.
Thanks Again..
Locked
