This discussion topic is read only Discussion topic: Ideal halo
This message was authored by: Angiewww
Ideal halo
Trying to connect to ideal halo and my wi fi is not on list, ideal have told me to speak to sky!!!! Some chance of that !  Can anyone help or advise tried to phone sky but just get robot so frustrating
Locked
Re: Ideal halo
@Angiewww
Typically devices such as that are confused by seeing the same SSID (network name) on both 2.4Ghz and 5Ghz bands.
As posted by @jamesn123
So to split the two channels you need to go to your router config page which can be found by typing 192.168.0.1 into your web browser. To access the page, you'll need;
username: admin
password: sky OR your WiFi password
- Select wireless from the navigation bar and scroll down a little and untick the 'Synchronise 2.4GHz and 5GHz settings'
- Scroll to the bottom of the page and hit apply.
- Once the page reloads you need to go to the 5GHz wireless settings page on the sub navigation bar below where you click wireless before
- In the 5GHz section you want to go to the box called 'Name (SSID)' and add something like 5g to the end of the current name
- Scroll down and hit apply
- Then on any wireless device you should now see two networks. One network will be the same name as usual and will be 2.4GHz band and the other will be the usual name with 5G on the end (Or whatever you typed). Connect any 5GHz capable device to the 5GHz network and see if it works correctly. The WiFi password should be the same if you havent changed it.
Locked
