This discussion topic is read only Discussion topic: I want to connect to Sky broadband if possible and I have an issue with my current Sky Q box disconn
This message was authored by: KDaly
I want to investigate a Sky broadband connection and I have an issue with my Sky Q box disconnecting frequently
Locked
Re: I want to connect to Sky broadband if possible and I have an issue with my current Sky Q box dis
@KDaly
If your looking to take up Sky broadband head over to Sky.com/shop
I am NOT a Sky Employee
@KDaly you can look online at Sky's current deals - Sky only use Openreach's infrastructure so speeds and products you can get will be similar to your current ISP if they also use Openreach's lines. The website will be able to tell you the products Sky can offer and give you the speeds.
Once you have an idea of what you want give Sky a call to confoirm the details and at the sametime ask about the issue with your Q box.
@KDaly
Is your current hub in the same room as your q box if not you may want to take out a broadband boost package to get the sky booster boxes
Enter your full postal address below and post the table to see whats available
Locked
