Discussion topic: How to block a device from Broadband
This message was authored by Kerry92 This message was authored by: Kerry92
Not sure if this is the right placce but I was wondering how do I go about stopping certain devices using the broadband?
Locked
This message was authored by MartinSom This message was authored by: MartinSom
Re: How to block a device from Broadband
How is that device connecting, via a cable or via wifi?
Kerry92
The devicce is connected via Wifi
@Kerry92  Does the device belong to a child and you are trying to restrict access at certain times?
Kerry92
Not a child but someone who I wish to restrict usage of wifi to.
This message was authored by Anonymous This message was authored by: Anonymous
Changing the WiFi password is an obvious solution.
Kerry92
Yes, that will be the last resort if I can't disconnect the deivce.
@Kerry92If you would like to totally stop someone from using the Wi-Fi change the password and connect all of the devices you want to and they will be unable to connect with the new password.
You can go into the router settings and add a firewall rule from there but it gets a little technical.
Kerry92
Thanks! Yeah I am not 100% tecch savy but I am looking into it.
Locked
