Discussion topic: How do I obtain a remote with voice control ?
Message posted on 08 Feb 2022 07:04 PM
I have a Sky Q box, but the remote does not have the voice control function.
How can I get a remote that has voice control ?
Message posted on 08 Feb 2022 07:06 PM
@frob1sher Give Sky a call.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 08 Feb 2022 07:11 PM - last edited: 08 Feb 2022 07:12 PM
Re: How do I obtain a remote with voice control ?
hi @frob1sher
Is it an old mini remote control, as most remotes have had voice control for quite some time?
Does the remote have a voice button either on the side or front and just not work - to use voice control it must be paired in bluetooth mode (& only one remote can be paired with a box)
Message posted on 08 Feb 2022 07:19 PM
@nigea99 this is my remote
Message posted on 08 Feb 2022 07:22 PM
@frob1sherWe can't tell from your photo, both types look the same from the front, the later one has a blue microphone button on the front but the older ones have a button on the side top right.
Message posted on 08 Feb 2022 07:23 PM
@nigea99 I tried to post a picture of my remote just now but it didn't seem to work so trying again
Message posted on 08 Feb 2022 07:24 PM - last edited: 08 Feb 2022 07:24 PM
hi @frob1sher It does indeed look like an older non voice remote
I have to admit I bought a voice control one for my mini after only a short while as I found voice control useful (as well as being bluetooth rather than IR) - That was now 3+ years ago
BTW Images have to be approved before they show and can a little while once approved to show also I think
As per the text you should see before you post in the grey header
Please provide as much information as possible, as you’re far more likely to receive a helpful response. Alternatively, upload an image or video using the buttons below to help describe your query more easily.
Pictures and videos added to your post will not appear immediately. These need to be approved by our moderators first, this shouldn’t take long.
Action will be taken against posts that contain explicit/illegal content or breach our terms and conditions.
Message posted on 08 Feb 2022 07:25 PM
@bob1234 thank you, it doesn't have a button on the side.
