This discussion topic is read only Discussion topic: Having a problem with ITV
This message was authored by: JohnChief
Having a problem watching ITV today. It keeps pixelating and freezing. Checked both sky q boxes and its happening on both. Every other channel is fine and all connections secure. If ITV has a problem then why haven't sky let us know
Locked
Re: Having a problem with ITV
Hi @JohnChief
Probably not a universal issue and a problem with your reception.
Might be worth rebooting the main Q box.
This message was authored by: pjhaahl
Is it ITV or ITV HD or both?
This message was authored by: Mark997
Having the same issue with ITV HD. It's the only channel it's doing it on and on all my mini boxes as well. Only seems to happen about 7pm at night really strange. Thankful for any ideas
This message was authored by: Rhonny
@Mark997
Your mini boxes get their TV signal from the main box, so if it affects the main box, it will naturally affect the minis.
It will be something that affects your main box at 7pm. Does someone come home with a big van passing your dish at 7pm each evening..?
Hi thanks for the response. Nothing I am aware of and it's only just started. My dish is to the rear of my property and no road there. Really weird and onnoying to be honest
This message was authored by: Mary015
ITV, ITV3 and ITV4+1 etc.    - I have found a few ITV channels on channel code         10.906 - V - 5/6 - 22
I hope it works for you.
This message was authored by: SDBro
Did you find out what the problem was, I've been having problems with ITV for months often saying no service as problem with satalite signal?
hi @SDBro in which case I suggest you call SKY to check your dish alignement
Locked
