4
This discussion topic is read only This discussion topic has been answered Discussion topic: Grey Screen using Sky Go on Macbook Pro Big Sur 11.2.3
This message was authored by: duncanjw
Experiencing the same issue as reported on several discussion threads - basically when I start watching channel it works for a few seconds then audio continues but screen is grey.
Tried suggestions to no avail.
1. I've done a clean delete/install but no change.
2. Sharing screen/Remote management are both disabled so that isn't the issue.
Great start (not) to new F1 season.
Avatar for duncanjw
This message was authored by: duncanjw Answer
Re: Grey Screen using Sky Go on Macbook Pro Big Sur 11.2.3
Resolved by rebooting MacBook Pro. Not a particularly satisfactory resolution but at least it worked.
Locked
Avatar for duncanjw
Installed Sky Go Version 21.2.2 (21.2.2)
Avatar for duncanjw
This message was authored by: msrajjc2
how do you disable sharing screen / remote management?
This message was authored by: liamski68
sort it out `SKY or I'm off
Locked
