This discussion topic is read only Discussion topic: Faulty box
This message was authored by: chrissykim
Faulty box
Every time a lorry or bus goes past our property the sky goes off, which is very regular, I only had my equipment fitted on 22/03
Locked
This message was authored by: pjhaahl
Re: Faulty box
@chrissykim
Is the dish fitted so low that when a high sided vehicle passes it blocks the line of sight of the dish. If so then there is a case for arguing it should be moved at no charge.
You need to call Sky
Locked
