This discussion topic is read only Discussion topic: Faulty SkyQ box
This message was authored by: hurstm
Faulty SkyQ box
Hi my skyQ box every morning says no signal flashes red then green I press a couple times what I assume is the refresh button at the front of the box and it sorts it until the day after and also it keeps completely wiping the box of all recordings and scheduled recordings
Has this happened to anybody else
Locked
This message was authored by: bob1234
Re: Faulty SkyQ box
@hurstmIt certainly should not wipe recordings etc I wonder if the hard disk is on its way out, I would talk to Sky so they can help and perhaps send an engineer out or change your box.
If you want to use the box VERY early in the morning check the eco settings and change to none/active.
The eco settings however should not affect  the recordings etc.
This message was authored by: SDR
Re: Faulty SkyQ box
Get on the phone and get them to send out new box.
A telephone number for Sky can be found at the bottom of this page -
https://www.sky.com/help/home
Stuart R
I am responsible for the content, but not the way it is presented, I have some sight issues
Auto-Correct is my enemy.
Sky Glass - No Puck
Locked
