This discussion topic is read only Discussion topic: Drop of speed.
This message was authored by: blade44
Drop of speed.
I’ve always had around 36mbps speed but over the last few weeks its dropped to 24mbps, having spoken to sky they are telling me that my location can only accept 25mbps and there’s nothing they can do !
I find it very strange that this has only occurred over the last few weeks when I’ve had speeds of 36mbps for over 5 years.
Any thoughts of why the sudden drop of speed?
Many thanks,
Locked
Re: Drop of speed.
@blade44
Can you post your router stats
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
Re: Drop of speed.
@blade44
Oh, and by the way could you enter you full postal address below and post the full table. This will give you the maximum attainable speed as well as other openreach data
Avatar for blade44
Re: Drop of speed.
Avatar for blade44
Re: Drop of speed.
2021-11-03.pngOpera Snapshot_2021-11-03_071700_www.broadbandchecker.btwholesale.com.png
Re: Drop of speed.
@blade44
Images need to be moderated
Avatar for blade44
Re: Drop of speed.
Ok, thank you.
Re: Drop of speed.
@blade44
Whilst waiting for bt wholesale what is your minimum guaranteed download ? Can you run tests from my sky app and post or copy and paste the details in more about your connection
Re: Drop of speed.
@blade44
Your guarantee may be below 32Mbps therefore you profile would be a 40Mbps. On saying that you may actually still be below the minimum . We need the details from more about your connection
Re: Drop of speed.
@blade44
Your line shows a fault with the raised margin. I've flagged your post to Sky, lookout for an email or message on the forum
I am NOT a Sky Employee
This message was authored by: dmy24
Re: Drop of speed.
Thank you for escalating, a chat request has now been sent 🙂
Avatar for blade44
Re: Drop of speed.
Spoken to Sky again today, they are still saying that my property will not accept no more than 25mbps so not sure where the 36mbps come from the last five years! They will not send an engineer out because there no fault that they can find.
My minimum speed is 28mbps so they said I could have a small refund because I am under the speed what they have guaranteed; they have also said I can leave at any time! Nice when I have been with them 22 years.
This message was authored by: mae-3
Re: Drop of speed.
@blade44
I'd give the router a reboot once just to see if the speed improves, eg: bad weather and overhead cable is the most likely reason when you rebooted the router when the router was last analysed the VDSL2 channels can cause issues. If the weather was anything like we had in Plymouth 5 days ago it was very windy and absolutely pooring down with rain. You could wait and see if DLM will do it itself and improve the speed?
Avatar for blade44
Re: Drop of speed.
I’ve rebooted the router, still no difference in speed.
Re: Drop of speed.
@blade44
A raised noise margin at 10dB is a clear fault, Sky should really address this issue by allocating an engineer in this case to fix the fault.
Locked
