32
Discussion topic: Disney + error 1027 mini box
Locked
This message was authored by Kate+Elizabeth This message was authored by: Kate+Elizabeth
Re: Disney + error 1027 mini box
I completed the software update before we have done a factory reset. Do you recommend the Factory reset? Does that wipe all recordings etc?
This message was authored by Rhonny This message was authored by: Rhonny
@Kate+Elizabeth
Yes, it will wipe all recordings. If you want to do a reset, do a Settings Reset. Go down to Settings but don't press Select. Instead type 0 0 1 Select to open the hidden menu. From there you can Reset Settings (you won't lose any recordings or preferences) which takes about 20 minutes. See if that helps.
This message was authored by Richard+upton This message was authored by: Richard+upton
Definitely do the factory reset on the mini box and then I think I did the software update after?
Checked the apps but and Mine then had barely any apps so did the app refresh and everything appeared and was finally able to log back into Disney
This message was authored by Wavis This message was authored by: Wavis
I'm doing the software update first. How long does that take ? Seems to be taking ages
This message was authored by Stebo This message was authored by: Stebo
Tried this twice, still not working 🤬
Had to speak with Disney and now resolved...you can have text chat with them.
@Wavis
Can you post what the solution was so that others know?
Essexbookkeeping
This message was authored by Essexbookkeeping This message was authored by: Essexbookkeeping
I done a full factory reset by going to settings and enter 0,0,1. Once this has been completed I had to switch the mini box off and on again to finish the reset. I then went to software version, reset and carried out a software update. Once this was completed Disney+ appeared in the Apps and I was able to log in as normal.
Hope that helps. This was only with the 1027 error.
Yeah google Disney+ and speak with them through message...it's easy and they respond straight away...mine took some time as I had bad internet connection and had to do about 3 different things....they said they have had a few people messaging them about the same issues so my advice will be contact Disney + and speak with them it will get sorted properly
This message was authored by Kei+M This message was authored by: Kei+M
Our agreement with Disney outlines that we should direct people to them when it comes to these types of error messages but we've reached out to Disney to see if there's anything we can do or help them with.
In the meantime, you're welcome to try some of the suggestions outlined such as the apps refresh, software update, and only if you're happy to wipe everything - a system reset.
Thanks,
Kei
Community Manager
This message was authored by Susan3030 This message was authored by: Susan3030
I have error message 1027. Spent ages on the live chat with Disney yesterday who told me to get in contact with Sky for help!
I turned off sky and my router. I then did a software update via settings menu. Was still getting the error.
I've now opened the secret settings menu (turned box off and went straight to settings before pressing 001. I'm now trying app refresh.
I was told by Disney to contact sky!
This message was authored by orangewhizz This message was authored by: orangewhizz
Hi, @Kei+M @ have Sky and Disney worked out any jointfix yet for this error. I don't want to do a full factory reset. All my miniboxes sign in but not my main box
It's currently with Disney who are investigating and they'll provide us with an update afterward but we've found refreshing the apps appears to fix it for quite a few.
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
Thanks,
Kei
Community Manager
Thanks, I'd already tried this but tried again with no success. Guess I'm going to have to wait for the Disney update sadly.
Locked
