This discussion topic is read only Discussion topic: Controller only changing volume and source
This message was authored by: Ellblake
Last night everything worked fine, we turned the TV on this morning and the remote only changes the volume and source (scart, AV etc) I have rebooted everything (twice) and replaced the batteries in the remote. I have checked the connections and nothing is working. The troubleshooting guide hasn't helped either.
Any ideas? Thanks in advance.
Locked
This message was authored by: LukeC1
Re: Controller only changing volume and source
Hi,
Could you please try pressing the 'SKY' button at the top of your remote and then trying to use it?
Let me know how you get on.
Luke
Home Service Field Engineer
Sky Glass. The only TV with Sky inside.
Want to find out more? Visit sky.com #SkyGlass
Please note: I have no account access and can only provide general advise and support.
Avatar for Ellblake
Hi Luke - none of the buttons worked other than the volume and source - the power button turned off the TV itself but not the sky box.
since posting, I googled how to resync the remote, I held down 9&7 at the same time, which has now enabled the majority of the buttons to work
however now, I can't use the volume buttons on the sky remote or the voice control or source
thanks
This message was authored by: Kenny-J
Sounds like you have Sky Q remote @Ellblake press 1&3 and then follow the on screen instructions to recod for your TV volume.
This message was authored by: Chadcharl
Hi,
thisbis happening to me now and when I press 1 and 3 together it brings up the page to re sync but I cannot press enter the button isn't working on my control
please help
This message was authored by: D-Dee
Re: Sky remote only working power button and changing volume.
My sky remote had been working perfectly prior to today.
It now only works the power on/off and volume buttons!
I've tried changing the batteries, rebooting/resetting the sky box, resetting and syncing the remote following the sky instructions, all with No success..
The sky remote still only works the power and volume buttons on my LG TV..?
Any suggestions or HELP to resolve would be appreciated.
@D-Dee sounds like your remote has had it, and will need to be replaced.
Locked
