4
This discussion topic is read only This discussion topic has been answered Discussion topic: Contrcat renewal
This message was authored by: RSkjabsdkf
Contrcat renewal
Extrememly frustrating time contacting Sky... 90 minutes to complete renewal. Trouble is, the price the guy gave didn't match what came thriough on a confirming email. Plus the next standing order is 100% higher than usual... I cant get through to Sky and there is no way of communicating... so I'm trying this "community" Anyone got any ideas of how to get hold of someone?
This message was authored by: GD1 Answer
Re: Contrcat renewal
@RSkjabsdkf  If you have a Sky Landline or Mobile yes, if with another provider you need to check your call charges to 01, 02 & 03 numbers in the UK.
Locked
@RSkjabsdkf   You will need to call Sky or use the following link https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
On the link provided (In the UK) it should include a Message Us option between 0900-1930.
You can also call on 150 from a Sky Mobile or Sky Talk line
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
If you don't see the Contact options on the link above make sure java script is enabled on your browser.
Avatar for RSkjabsdkf
Re: Contract renewal
Thank you
So, calls made to Sky are free?
Locked
