Discussion topic: Code PFE 9001-IH
Locked
This message was authored by Fran0004 This message was authored by: Fran0004
Re: Code PFE 9001-IH
No this error occurs regardless of which channel is showing on the box - the only way to get rid of it for me was to turn the box off
This message was authored by SmurfyPops This message was authored by: SmurfyPops
This error has suddenly dissapeared and I can now watch live and Sky Q recorded programs on my PC.
Happy days
This message was authored by Beardpowerr This message was authored by: Beardpowerr
Are you able to watch it on ur PC now? I still can't figure this out and Sky are useless with their support they have zero clue
The adviser said to me on the phone "Well it works on your phone do you really need a PC to watch Sky" LOL
I was so baffed
Yeah. It's working fine on my PC
Seems I spoke too soon.
After a week or so of the Sky Q windows app working perfectly, this error has re-apperaed.
Utter garbage
Funny thing is we have all figured out it works fine on windows pc if the skygo app does not connect to sky q box but Sky engineers haven't and not found a fix it's a total and utter nonsense... Gone downhill
mm,. Re: Code PFE 9001-IH
hmmm, if I connect to a VPN, I can now watch recordings from my SkQ box.
What a complete mess this app is !
This message was authored by Bling1981 This message was authored by: Bling1981
Come on Sky please sort your [removed], this is your error fix it.
moderator note: removed swearing
UPDATE:
Today, nothing is working on this atrocious app !
I can't watch live TV, catch-up or recordings on my box.
This is utter garbage
This message was authored by TechmanagerMal This message was authored by: TechmanagerMal
@SmurfyPops  is this with the Disconnect from Q update?
Passing on the tips I have learned in over 24 years as a more than satisfied Sky customer.
whats that update?
There is an update that is going to be rolled out over the coming weeks which will allow the user to disconnect the Sky Go app from their Sky Q box which might fix some of these errors.
Ah OK, thanks.
If the app is disconnected from the Sky Q box, how can we watch recordings ?
@SmurfyPops  By using the option to download to your device.
This message was authored by Qual This message was authored by: Qual
Can confirm that with the update, in preferences turning off connection to Q does finally allow you to watch Live TV.  However Recordings are then missing, though they have always been unplayable with the 9001 error for me. One step at a time.
Locked
