Discussion topic: Can’t update sky Q box
Message posted on 24 Sep 2021 10:32 AM
Hi! I'm after some help please. I keep having the software update coming up on my screen, however it won't let me click ok or later.
I have restarted the box and tried again, hasn't worked.
ive also tried to update it from settings, but it's getting stuck on the part where it says update in progress. How long does this usually take please?
Message posted on 24 Sep 2021 10:36 AM
Re: Can’t update sky Q box
Hi @EmilyW29 The Sky Q box does not prompt you to update. If I was a betting man I would lay odds on it's your TV prompting you to update. Try using your TV Remote.
