Discussion topic: Can't port existing landline number from Now broadband (FTTC) to Sky FTTP as same network?
Message posted on 22 Apr 2022 03:36 PM
Trying to switch from Now FTTC to Sky FTTP and keep my existing landline number. Apparently some internal Sky issues that prevents porting the existing number as it deemed by Openreach to be on the same network (ie Sky) ? Only option is to join on FTTP with a brand new landline number (which I don't want).
Does anyone know is Sky will be fixing this issue anytime soon?
Or if I move to Sky FTTC and keep my landline number (not sure this is even possible) then do an upgrade to FTTP can I keep the number? 🤔
Message posted on 22 Apr 2022 03:40 PM
Re: Can't port existing landline number from Now broadband (FTTC) to Sky FTTP as same network?
That has caused issues in the past. Surprised you got broadband. Both are owned by comcast and effectively appear as the same telecoms provider.
