6
This discussion topic is read only This discussion topic has been answered Discussion topic: Can a Sky Wireless WiFi Adapter Connector SC201 be used in place of a Sky SD 501 Connector?
This message was authored by: MichaelBere
A friend of mine has a Sky SD501 Connector (on a Sky+ Box) that seems to have stopped working.
I have a Sky Wireless WiFi Adapter Connector SC201  with RJ45 Ethernet connections that I no longer use, as my later 2TB Box had built-in modem.
Can the SC201 be used as is instead of the SD501 on my friend's Sky+ BOx?
This message was authored by: Mark39 Answer
Re: Can a Sky Wireless WiFi Adapter Connector SC201 be used in place of a Sky SD 501 Connector?
I haven't tried it, but I can't see any reason why it wouldn't work. You'll need the the power supply that comes with the SC201 of course.
Locked
Avatar for MichaelBere
Level 2 icon
Thanks Mark39 for that. Yes, have the power supply. So will try it.
If you have a moment to let is know how you get on, it would satisfy my curiosity!
Level 2 icon
Certainly will do. Have posted it to another part of the country. So will be a few days. Thanks.
Level 2 icon
Hello Mark39. Glad to say that, as you surmised, the SC201 works grand in its new home. Their Sky+ Box has a RJ56 connector so takes the "new" one. I gather the connector on SD501 is of the mini type. Thanks again.
Good to hear, @MichaelBere. Many thanks for letting us know. 🙂
Locked
