8
Discussion topic: Asus xt8 or nest wifi
This message was authored by DipDipDipam This message was authored by: DipDipDipam
Howdy peeps,
Hoping some can help/advise.
So I've been struggling with my smart devices at home. I've got about 100.
The sky sr203 obviously can't handle it all, so I need to upgrade my system. I've been looking into threads on here and can see the Asus xt8 is highly recommended. But not sure if it's the best option for me.
I've got one sky q box, 4 sky q mini boxes and one sky booster. All connected wirelessly with no realistic way of hardwiring them all.
I'm guessing it'll be best to keep the sr203 as my primary router and then connect a xt8 to it or something like nest wifi (although I realise nest wifi isn't WiFi 6 but probably a cheaper option if multiple access points are needed). This would be on the ground floor, and I've got 3 floors.
Can you connect the xt8 as the main router and then connect the sr203 to it so my mini boxes still work?
There are 2 mini boxes on the ground floor, sky q + 1 mini on 1st floor and 1 mini on the 2nd floor. The 2nd floor mini is currently disconnected but I do have a booster up there to help with the signal in my bedroom.
Thanks for any help you can provide.
Sky q 2tb HDR, ultrafast 150mb, 4 mini boxes, Asus Zenwifi xt8 mesh WiFi x 2
Full sky package except kids & bt sport
Samsung 65" QLED TV with 6500k CRI 98 bias lighting and blackout blinds, Denon X3600h AVR, Dali Oberon 7 floor standing speakers, vokal centre speaker, Oberon on the wall rear speakers, c1 Atmos speakers, e12f subwoofer, Panasonic DPUB820 4k blu ray player, Chromecast with Google TV, Atacama Evo hifi rack and about £1000 worth of cables to go with it all
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: Asus xt8 or nest wifi
@DipDipDipam
Are you on full fibre fttp or superfast fttc
Your best option to maintain the 5ghz  connection to the minis etc would be to use the sr203 and ethernet the xt8 and put the asus in access point mode. The sr203 and xt8 5ghz shouldn't clash as the xt8 can use 5ghz freqs well above the sky hub
Locked
@DipDipDipam
DipDipDipam
Fttp. I'm on ultrafast 1. The sr203 is connected to a bt openreach ont box.
@DipDipDipam
Then the xt8 itself can be directly connected to the ont as well and authenticate skys network so that the sr203 isn't needed. Again the wifi connection will use the 2.4ghz wifi as opposed to the more robust 5ghz.band. The option would be to place the xt8 strategically so that they mesh via wifi but ethernet to the sky q and miniboxes
DipDipDipam
Isn't the 2.4ghz network not ideal for the minis?
Hardwiring isn't an option unfortunately. Although I'd really love to be able to. I live in a townhouse and the plasterboard in every room is dot and dabbed to the block work so no room to feed cables.
It more to do with interference from neighbouring ssids and certain household devices
DipDipDipam
Okay thanks for that. That definitely helps. How do I go about extending the network? Is it just more xt8 devices or do they normal matching extenders?
Trying to work out if maybe something like the nest wifi is more wallet friendly and beneficial. Don't mind spending more though if the best is miles better.
This message was authored by Thornhill5 This message was authored by: Thornhill5
The Asus XT8 seems like the better option going from reviews/speed tests that you read about. Extending the network is a case of adding another XT8 to the existing network. XT8 unlike the Nest uses a backhaul band as well purely for communication between nodes.
DipDipDipam
Ended up with the Asus xt8 and it's amazing. So perfect for my needs.
Locked
