This discussion topic is read only Discussion topic: Adding Netflix to sky q
This message was authored by: Kevcfc
I have just had sky q installed, all good yet does anyone know if I can add Netflix and what the monthly cost would be
i have normal sky contract with hd added
Locked
This message was authored by: PeteRG41
Re: Adding Netflix to sky q
It's £5 a month on top of your bill.  You're looking for the Sky Ultimate package.
For your set up, you'll get the Netflix HD tier as part of your package.  If you upgrade to UHD, you'll get access to the Netflix UHD tier for no additional cost (although you pay for Sky UHD).
Log into to Sky.com and look for the Ultimate package there. - It should be easy to find under the "deals" button.
____
Pete.
This message was authored by: fizzdisco
@Kevcfc
Check that you don't already have Netflix as part of your package. Sky Signature often includes it.
Have a read here, the Sky Q Netflix FAQ details all you need to know and has links to add it online;
Netflix FAQs | Sky Help | Sky.com
Locked
