The content on this page may be out-of-date or have been superseded by newer information. Links on this page to other sites may not work and contact information may be inaccurate. This page has been archived for future reference.
14 Feb 2022 12:00 PM
I cannot access Duo lingo in my house or others with sky broadband. It works in places with different provider even in hotels. I have had no problem after nearly 3 years using teir app, just suddenly stopped a few weeks ago. I don't want to reinstall in case l lose 3 years progress. All other apps are fine. Please help or suggest how l contact sky or Duolingo, the latter seems unresponsive by email
14 Feb 2022 12:11 PM
Although i cannot think of a reason why broadband shield would block it that would be the first port of call
Use my sky app to access broadband and talk settings then broadband shield and initially disable to see if it works then you may have to allow the site in custom settings
15 Feb 2022 10:11 AM
Posted by a Superuser, not a Sky employee. Find out moreThe two usual causes would be broadband shield or your public IP. Make sure Sky Shield is disabled, then switch the router off for 30mins to clear your public IP.
