2
This discussion topic is read only This discussion topic has been answered Discussion topic: 14 Peaks
This message was authored by: Skull+Treaty
14 Peaks
If you haven't already, try 14 Peaks on Netflix. May or may not be your thing and just the first 15 minutes should be enough to give you a steer. I recommend that you do not read up on it first though. I believe not knowing made it all the better for me.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
Avatar for Skull+Treaty
Level 13 icon
This message was authored by: Skull+Treaty Answer
Re: 14 Peaks
I thought it was a docuseries rather than just the one. Still, I enjoyed it all the same!
Locked
Level 13 icon
Re: 14 Peaks
This message was authored by: trevforum
Re: 14 Peaks
Looks like the auto escalation is a bit sensitive.
Sky Stream, Sky Glass, Panasonic DX902, Pioneer LX-901 7.1.4
Locked
