Discussion topic: 0845 call from Mobile
Message posted on 23 Aug 2020 05:07 PM
Hi can you explain call to 0845 " 5p a minute " for 17min 50 secs. costs £9:00
0845 625 . Calls cost 5p per minute
Message posted on 23 Aug 2020 05:13 PM
Re: 0845 call from Mobile
While you re not talking to Sky, what is it you want explained ?
Message posted on 23 Aug 2020 05:17 PM
Hi thanks for answer but would like a message from SKY employee to explain issue. But @ present SKY are not taking calls about billing !!!! .
Message posted on 23 Aug 2020 05:23 PM
They are taking calls, but the trick is not to say billing when asked why you are calling but on here you still haven't said what your question is, your title says "call from" and your first post says "call to" ?
Message posted on 23 Aug 2020 05:39 PM
Re: Mobile to 0845
Sorry meant call to 0845 from Mobile
Message posted on 23 Aug 2020 06:41 PM
Re: Mobile to 0845
Hi @CrazyJock have a look at this and it may help, there is an access charge per minute as well as the call cost per minute.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 23 Aug 2020 07:38 PM
Re: Mobile to 0845
Message posted on 24 Aug 2020 09:27 PM
Although i had assistane from members ,no staff from SKY "billing " have even made contact with me.
Message posted on 24 Aug 2020 09:31 PM
Hi @CrazyJock as this is mainly a customer to customer forum with no account access (even the sky staff) no one from sky will contact you, you will have to call them on 150 from your phone.
Message posted on 24 Aug 2020 09:37 PM
@CrazyJock - Calls to premium rate service numbers (e.g. 084, 087, 09 numbers & 118) - These have an access charge & a service charge, so thats why the call in question is so expensive.
Just a tip for future reference. If you need to call a premium rate number go to - https://www.saynoto0870.com/ - Here you can convert the number into a regular landline number.
I hope this helps.
Message posted on 24 Aug 2020 09:58 PM
Thanks 63johnw but as mentioned earlier they are not accepting calls to billing !!! .You mentioned to avoid billing can you recommend another option . cheers again for assist
Message posted on 24 Aug 2020 10:15 PM
All you can do is to dial 150, ignore the covid message and question, stay on the line and when asked why you are calling say Mobile.
Message posted on 26 Aug 2020 11:04 PM
Hi @AimeeLou031 AimeeLou031
The number is 0845 625 and if you read number it states
Message posted on 26 Aug 2020 11:13 PM
0845 Business rate numbers up to 7p and your phone company’s acess up to 7p and your phone company’s acess charge
Message posted on 28 Aug 2020 04:17 PM
@CrazyJock - Another option when it comes to premium rate numbers, you can put a spend cap on your SIM to stop any unwanted charges.
Take care 🙂
