Discussion topic: Help help help
This message was authored by: Annie30
Help help help
I need to change my Sky tv package as it is way too expensive
Re: Help help help
@Annie30 give Sky a call to see what they can do for you.
This message was authored by: Steve9417
Re: Help help help
What number should I call, everything seems to be AI generated
Re: Help help help
@Steve9417
What help do you need so can we help you via here to save you having to make a call ?
Re: Help help help
I've recently retired, and either need to reduce my bills or cancel my sky package and go elsewhere
Re: Help help help
In that case @Steve9417 you will have to contact Sky about this so the number might be visible at the end of the help flow:
https://www.sky.com/help
Or via the phone 150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone.
Sky Assistant is also available 24 hours a day on sky.com/help with rapid responses.
You can also contact Sky via social media:
https://helpforum.sky.com/t5/Online-Apps-Email/Want-to-private-message-Sky/ba-p/4895295
