24 Dec 2022 01:40 PM
Hi I moved my 80yr old father over from BT to Sky and everything was fine and great but in the last three weeks he has been having a problem with ringing me.
When he rings my Virgin landline it's saying my number does not exist although even know we can ring it via a mobile and anyone else not with sky can ring me .
He can ring other numbers fine and I can ring him from my landline and even if you press 1471 to ring back it says number does not exist
Could anyone please point me in the right direction to sort this .. as I don't feel happy that my 80Yr father cannot contact me if he needs to.
24 Dec 2022 01:44 PM
Posted by a Superuser, not a Sky employee. Find out moreIt will need to be reported to Sky, from his number the free number to use is just 150.
24 Dec 2022 03:42 PM
I have been through to sky 3 times and virgin twice they run line tests and all is ok I have now just found out my sister who is with sky can't ring me either getting same message this number does not exist.
24 Dec 2022 04:00 PM
Posted by a Superuser, not a Sky employee. Find out moreUnfortunately there's little we customers here can do to get this put right. It's a matter of speaking to Sky,again, I'm afraid. I doubt it's a problem with your line so no amount of line testing is going to find the problem. More likely it's a networking/routing issue.
26 Dec 2022 04:17 PM
I have exactly the same problem. I can't even ring my virgin landline from my sky mobile. My son has a Vodaphone mobile and can he can get through. This starting happening around the three weeks ago also.
26 Dec 2022 04:19 PM
You'll need to do the same then, I'm afraid.
28 Jan 2023 07:25 AM
Hi , same thing happening to me. Just switched from BT landline to Sky and now can't call my parents who are with Virgin.
It just says the number you have dialled can't be recognised.. but they have had the same landline for 40+ years!
My parents can dial me no issues.
Have reported to Sky, who suggested my parents need to speak to their provider, however reading these emails it suggests to me the issue is with Sky.
03 Feb 2023 07:04 AM
I'm also experiencing this problem. We reported it to Virgin in November. Since then they've simply pointed to an area outage, but there's no actual evidence the outage is even related to this issue. So, we're hitting a brick wall with Virgin.
I also called Sky on Wed 1st Feb 2023 and they insisted nobody had reported the issue to them and there were no active investigations into this issue. I pointed to these forums. The Sky tech support chap dismissed these Sky forums as a poor source of quality information posted by people who don't provide enough clarity about the issue. They seem to disregard these forums. I was taken aback by this attitude. It seems that if customers aren't able to articulate and identify the exact problem with technical preciseness, they're aren't interested in investing energy in investigations. (They want customers to identify the problem before they lift a finger to fix it.)
He also stressed that there is no collaboration between Sky and Virgin.
I will report it again.
03 Feb 2023 09:43 AM
Hi, I just wanted to give an update . My situation has been resolved and my SKY landline does now connect to my parents Virgin landline.
It wasn't easy and I had to make numerous calls to Sky to resolve, but it definitely isn't anything you can resolve yourself.
I was told all sorts, such as had my parents accidentally barred my number ( no!), that lines were checked and there was nothing wrong with them .
It is a routing/ networking issue. SKY did need examples of when we had tried the line (ie specific dates and times when the call had failed to connect). Other positives are my dad can now use his mobile to phone his own landline!
This forum massively helped me, and showed my situation wasn't unique, companies shouldn't dismiss them so easily.
03 Feb 2023 11:07 AM
That's excellent news Caro77. Can I just confirm that the fault was on the Sky end it was Sky who rectified it? Can you shed any light on what they did please?
Thank you.
03 Feb 2023 12:13 PM
Hi, I went through Sky, I spoke to a Tech guy from Sky who said it would be escalated and could be solved quite easily. Within a matter of hours I could call my parents on their landline.
It is a routing/ networking issue. Tech guy did not say whose error it was. The hardest part was getting the issue taken seriously, it took several phone calls to various people before issue was taken seriously and dealt with.( ie passing issue back to other supplier ie virgin/ told that maybe my parents had accidentally barred me).
Sorry I can't be of any further help, but good luck
03 Feb 2023 12:25 PM
That is helpful. Thank you. The issue couldn't have been resolved within hours unless it was handled internally by Sky, so it's almost certainly on the Sky end. Thanks again.
03 Feb 2023 03:28 PM
Update: I called Sky for the 3rd time today (03.02.2023). I explained Caro77's outcome and I asked the issue to be escalated. For some reason they asked us to provide examples of numbers that weren't able to get through to the VM landline. I found this baffling and stressed that we couldn't provide an exhaustive list explaining that anyone with a Sky number (landline or mobile) should be able to get through. They resolved the issue within 2 hrs. Friends confirmed they can now get through. Hurrah.
The moral of the story is that Sky will continue to fob you off until there's a critical mass of customers facing the issue and it becomes undeniable that it's a problem with their service.
On average, new discussions are replied to by our users within 80 minutes
