Discussion topic: Phone calls keep dropping out
This message was authored by jdcastro This message was authored by: jdcastro
Hi,
I'm using a landline phone with my Sky hub and have been having trouble tonight.  A couple of times the phone call just dropped out (after about 20 mins).
I also had trouble when dialing a landline number, as each time I dialed I got nothing at the other end.
Has anyone else been having similar problems recently?
Jonathan
Salisbury, SP2
Re: Phone calls keep dropping out
@jdcastro
See if you can run this line test to see if a fault is found outside of your property and if something is found you can book an engineer repair:
https://www.sky.com/help/articles/fix-phone-problems-start
On average, new discussions are replied to by our users within 80 minutes
