10 Aug 2023 03:08 PM
I am getting FFB installed next week with Sky Talk but I am wondering, will my current analogue telephone work when plugged into the presumably new socket/hub? In other words, a) will I still plug my existing landline phone into my existing analogue line or b) will I need a new home phone handset (presumably VOIP) to plug into the new hub/router? Any help gratefully received, thanks.
10 Aug 2023 03:11 PM
Posted by a Superuser, not a Sky employee. Find out moreA VOIP handset definitely won't work. You'll simply need to plug your existing handset into the phone socket at the back of the Sky Hub. The Hub does all the necessary conversion to send your phone signal via your fibre connection.
10 Aug 2023 03:15 PM
@Mark39 thanks so much for such a swift and helpful reply!
31 Aug 2023 02:20 PM
Fibre broadband installed on Tues 29th August and now my landline is not ringing for incoming calls but i can call out have tried everything that has been suggested ie; turning everything off for 10mins no change checked phone volume etc etc etc still won't work any ideas anyone thank you
31 Aug 2023 02:30 PM
Is your phone plugged into your Sky Hub? Is the Voice light on the Hub lit? Green or amber?
31 Aug 2023 05:35 PM
Hi thanks for your reply happeee to say sky have sorted it took an age to get through but am now up and running 🏃♂️ 😀 👍
On average, new discussions are replied to by our users within 80 minutes
