19 Mar 2023 07:32 AM
I'm on a Sky+ box and finally managed to figure out how to watch Yellowstone as it wasn't listed as a box set. The only option was via Catch Up TV.
However now I'm at the end of S4 the automatic download of the next episode doesn't work. S4 Ep10 triggers the download of S5 Ep2, which triggers the S5 Ep1. Which triggers nothing so I have no way of accessing S5 Ep3.
It's incredibly annoying that I'm paying for this service but can't access the show as a box set like anything else.
Anyone else found this?
19 Mar 2023 10:05 AM
Posted by a Superuser, not a Sky employee. Find out moreIt is there for me so go to Catch Up > Paramount+ > Yellowstone and download it yourself if it hasn't been trigged when you download episode 2. You can also use something like the Sky Go or Sky+ apps to start the download.
20 Mar 2023 12:05 PM
Thanks for the tip however whenever I go to Yellowstone via Catch up it only wants to either play S1 Ep1 (if it's still downloaded onto the box) or start downloading S1 Ep1 if I have deleted it (properly, not in deleted items).
I've never actually used Catch Up in all my years as most things were in box sets, it seems really limiting in the way it works.
And the show unfortunately isn't acceessible via the various apps.
20 Mar 2023 12:21 PM
It is for me, via the Sky+ app. Catchup > Paramount+ > Yellowstone.
You can then find the episode and remote download it to your box.
20 Mar 2023 12:40 PM
This is interesting, when I follow what you've said the only option is to download 1/1. There's a few shows like that.
However I have gone to it via the Drama section and found Yellowstone there which allows me to download my choice of episode. Finally.
Thanks for engaging, been most helpful. Like cracking the Enigma code.
20 Mar 2023 08:06 PM
I find it a lot easier to keep track of all the Paramount series by going through catch-up and then the relevant category, ie drama.
20 Mar 2023 08:07 PM
Yes seems the best way, weirdly specific though
12 Apr 2023 02:17 PM
I can't find Paramount on Sky go and like others it automatically downloaded Ep 2 series 5 - then Ep 1 then nothing? Can't find it in the search bar or anywhere else - are Sky still working with Paramount?
12 Apr 2023 02:23 PM
Hi,
The way around I found was to use the Sky Plus app, g to Catch Up TV, Paramount +, then tap Drama a the top.
Navigate to Yellowstone and you will be able actually choose episodes to download. Download episode 3 and then things should work normally after that.
12 Apr 2023 04:15 PM
perfect found it thank you!
12 Apr 2023 11:12 PM
Posted by a Superuser, not a Sky employee. Find out moreThere are 47 episodes showing on my Sky+HD box under Catch Up > Paramount+. Is that not all of them?
24 Jul 2023 06:56 PM
The same happened to us we kept going forward to series 5 same as you. Now we may be at the end of Series 5 but not sure how many episodes there are or indeed if we are at the end
25 Jul 2023 06:03 AM
Have a look on the Wikipedia page for the show and look at the episode list. The show did have a mid season break in S5.
On average, new discussions are replied to by our users within 100 minutes
