Discussion topic: Woken this morning to a red flashing light on sky+ box.
This message was authored by natasha1975 This message was authored by: natasha1975
Tried all the steps to reset it with no luck so far, was working well last night. Any ideas? Should I order a box from Amazon if broken properly or go for sky q? Thanks
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Woken this morning to a red flashing light on sky+ box.
Flashng red light usually indicates a hardware fault, only you can decide if Sky Q is right for you
Look for DRX895 model of Sky+HD boxes for replacement, you could also go for the DRX890 (smaller HDD)
On average, new discussions are replied to by our users within 100 minutes
