30 Aug 2023 11:17 PM
To schedule won't load on sky + box even thought connected to sky Q box Reset and re booted numerous times
30 Aug 2023 11:20 PM
I don't understand the above. Can you clarify?
30 Aug 2023 11:35 PM
TV schedules won't load on our sky box which is connected to sky q. Constantly says waiting for to schedule. It's the sky box in bedroom which I believe is a sky + box
31 Aug 2023 05:39 AM
You can't mix a Sky Q and Sky+ box. You need to clarify which main box you have; Sky Q or Sky+. If it's Sky Q and the box upstairs is a mini box we can move this thread to the correct board and advise you.
31 Aug 2023 08:09 AM
Posted by a Superuser, not a Sky employee. Find out more@SNGalt does your bedroom Sky box have a cable at the back which goes to your satellite dish? If so, you're right, it's a Sky+ box but unfortunately it won't work if you have a Sky Q box too, unless you specifically told the Sky engineer you want to keep it.
On average, new discussions are replied to by our users within 100 minutes
