Discussion topic: Sound quality
This message was authored by penfold72 This message was authored by: penfold72
Sound quality
My dad has an older sky+HD box. He's been complaining of poor and muffled sound quality, compared to sound coming from the free view part of the TV. I can't see any volume control in sound options, I'm sure there used to be one. He's fiddled with sound settings, and sound perfectly adequate on apps and freeview but once switched to the sky input, all goes muffled and noticeably quieter. Is this possibly due to the age of sky+HD, and should he be contacting sky to get upgraded to q. The input he's on is an arc input.
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Sound quality
Sound control was removed on Sky+ many years ago, you just have to change the TV volume for the sky box sometimes you need to adjust yhe volume per programme/channel
You cannot  compared the Sky box sound output to the TVs internal tuner  as they use different hardware
This message was authored by Mark39 This message was authored by: Mark39
Re: Sound quality
@penfold72 check that 'audio over HDMI' (I think that's the name of the setting) is set to 'normal' not 'dolbyd'.
penfold72
Re: Sound quality
@Mark39 @Annie+UK
He's switched off all audio processing. I'll get him to check the hdmi setting.
On average, new discussions are replied to by our users within 100 minutes
