03 May 2022 10:58 PM
My Sky+ box is working fine on every channel except Sky History and History 2 (and the +1 equivalents).
Last week the picture started breaking up. Then it started giving a constant no satellite signal on screen. Five days later it's the same. Can't watch record or dowload. Every other channel works fine!
Any ideas please?
04 May 2022 12:40 AM
@ElleeB wrote:My Sky+ box is working fine on every channel except Sky History and History 2 (and the +1 equivalents).
Any ideas please?
@ElleeB Your satellite dish may be misaligned and will require an engineer to correct this. Do you have your own dish or are you connected to a communal dish?
Own satellite dish, Visit sky's homepage https://www.sky.com/help/home and scroll to the bottom of the page and click on "Need more help?" to display the contact number to arrange an engineer visit.
Communal dish, Contact with your building management/landlord to report a fault, communal dishes are not maintained by Sky.
09 Aug 2022 12:33 AM
Getting the same issue on Sky History. My dish is aligned properly. The picture breaks up and the sound cuts out. It has only recently starting playing up.
09 Aug 2022 07:56 AM
Check your signal strengths (Services > Settings > Signal) while tuned to one of these channels. The white part of all four bars should consistently be at least half way across. If not, there's a problem with your dish or cabling which will require an engineer to investigate.
08 Sep 2022 12:06 PM
I had the same problem with these channels plus a couple of MTV channels were pixellating. I changed the LNB on my satellite dish (easy for me as I can access it with a stepladder) and everything was back and working. The LNB was about 8 years old so I think it was just starting to fail.
08 Sep 2022 01:21 PM
Entirely likely. Performance tends to degrade after around 5 years.
10 Sep 2022 12:43 PM
Further update....my original old LNB was an OCTO (8 outputs). I changed it for a quad LNB (4 outputs) which I had as a spare. My installation uses 6 outputs normally so I left a couple of cables unconnected while I was using the Quad. This got everything working properly on Sky History etc. with no loss of signal or pixellation that I could see anywhere across channels.
I next bought a new OCTO LNB and installed only to find Sky History/History2 were heavily pixellated as were some other channels again. I checked all connections and connected only the 2 cables from my main Sky box to the OCTO without any improvement.
All LNB's seem to be SKY original items with their labels on the units and the boxes.
I'm thinking now about dish alignment with the OCTO being slightly heavier than the Quad.
Any thoughts?
On average, new discussions are replied to by our users within 100 minutes
