04 Sep 2023 11:08 AM
Hi everyone. I've had sky q but they didn't change the LNB satellite as pre sky q box I had the old sky hd box, I actually had to buy another sky hd box as I threw mine out, but it keeps saying no signal, any ideas to how to get the free view channels back on without it saying no signal?
04 Sep 2023 11:10 AM
Posted by a Superuser, not a Sky employee. Find out moreIf you had Sky Q the LNB was changed. Sky Q won't work with a Sky+ LNB. You'll need to get it replaced with a standard LNB.
04 Sep 2023 11:59 AM
The LNB must have been changed to facilitate Q box use, and chances are it was a Q-only LNB which was put in place.
04 Sep 2023 12:40 PM
I just said the LNB wasn't changed when they installed the sky Q
04 Sep 2023 12:44 PM
Sky Q uses a Wideband LNB, Sky+ does not use wideband LNBs so it would be impossible for Sky Q to be installed on a Sky+ LNB and work!!
04 Sep 2023 12:58 PM
So a universal lnb is required?
04 Sep 2023 01:07 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you have a HyBrid LNB then you need to make sure the Sky+ is connected to the correct ports on the LNB
On average, new discussions are replied to by our users within 100 minutes
