14
Discussion topic: Remote control
This message was authored by Barrie54 This message was authored by: Barrie54
Remote control
Is a SKY SC030 remote control a direct replacement for a URC 1616-10-01RO1 SKYHD rev.10 remote control.
This message was authored by Mark39 This message was authored by: Mark39 Answer
Re: Remote control
OK, try this:
1 Press "TV"
2 Press and hold "Select" and "i" together until red LED flashes twice
3 Press "0" to operate a Digibox
4 Press "Select" - red LED should flash twice
5 Press "Sky" and the remote should now control your Digibox.
Re: Remote control
A quick search online indicates that the two are compatible. The SC030 remote is an official Sky remote. If your current remote controls your TV, you'll need to programme the replacement with the correct code in order to do the same.
Barrie54
Re: Remote control
Remote will control television but will not control SKY box, will it need programming for SKY box.
Re: Remote control
After conrolling the TV have you then pressed the Sky button before trying to get it to control the box ?
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Remote control
You only program Sky remotes to a TV they already know how to control the Sky box as that is their primary purpose
Re: Remote control
It's a Sky+HD remote. Do you have a Sky+HD box?
Barrie54
Re: Remote control
Caesarome
I pressed the sky button but nothing happened, suspect fault on remote as works fine on old remote.
Barrie54
Re: Remote control
Mark39
No is not a sky+ box it is quite old now so this could be the reason.
Re: Remote control
The Remote is configurable, but what type of Sky box is it?
Sky Digibox (no HD and no record or playback capability)
Sky+ (records but no HD)
Or Sky+HD (records and has HD)?
Barrie54
Re: Remote control
I think it is a skydigibox as it has no playback facility on it.
Re: Remote control
OK, try this:
1 Press "TV"
Barrie54
Re: Remote control
Mark39
Thanks Mark it now controls both television and Sky box. @Mark39
This message was authored by Richard-B This message was authored by: Richard-B
Re: Remote control
Many thanks Mark for the above info. My sky 100 remote has problems with buttons not working so my son gave me a Sky + HD remote which while it worked on his sky box it did not on mine, a now old digibox. Using your information it now works both the box and TV. At some time in the future it may need to control his box ie revert to original settings. Can you advise the procedure.
Re: Remote control
It's the same procedure, substituting a '2' (from memory) for the '0'  in step 3. I'll check and confirm later today.
Re: Remote control
Confirmed.
On average, new discussions are replied to by our users within 100 minutes
