Discussion topic: No bbc due to sd
This message was authored by Wardy46UK This message was authored by: Wardy46UK
No bbc due to sd
I have had a skysat box for a number of years but now cannot get bbc. What options do I have ie upgrade box or what.  Your help is required, Colin
This message was authored by Mark39 This message was authored by: Mark39
Re: No bbc due to sd
You can either buy a used replacement Sky+HD box from ebay etc or if you have a current subscription to Sky, you can upgrade to Sky Q
Wardy46UK
Thanks for coming back to me.
I do not subscribe for trhe skysat box.
If I could obtain a sky + hd box is there an ongoing cost.
What is the advantage of Upgrading to sky Q and at what cost
Regards
Colin
No, but there may be issues pairing your Viewing Card with the replacement box, if you don't have a subscription.
You have to have a subscription for Sky Q.
Regards
Colin
This message was authored by Wardy3246 This message was authored by: Wardy3246
Is it not possible to obtain a newer box/card from yourselves that will provide programs we have been used to for years
Regards
Colin
@Wardy3246  Sky Q or Sky stream are the only other boxes now available from Sky.
Also have you created a new forum login as this thread start with Ward46UK also called colin?
Sky+HD boxes haven't been manufactured since 2016. Even to customers with a subscription, they no longer provide replacement Sky+ boxes. A replacement Viewing Card wouldn't make any difference (and Sky won't provide one anyway to a non-subcriber).
If you don't have any subscription to SKY & still want to receive TV via Satellite then you may be best getting a Freesat Box
This message was authored by Exiled-in-HH This message was authored by: Exiled-in-HH
Sky have moved to a subscription only loaned equipment business... The only Sky device you can now buy are Sky Glass TVs🤔
The "Manhattan SX Freesat HD Box" which is still available is your cheapest Freesat option😉
Exiled in HH
Wardy46UK
Thanks for you help
I will try to obtain a second hand unit hoping it workes and compatable
Regards
Colin
It's really only worth buying the last couple of models of Sky+ HD box: these are typically about £30
Sky +HD DRX895WL 2TB. Built in Wi-Fi Lite Box (Telephone ports removed)
Sky +HD DRX890WL 500GB. Built in Wi-Fi Lite Box (Telephone ports removed)
Sky +HD DRX895W 2TB Replaced with DRX895WL (Built in Wi-Fi Lite Box)
Sky +HD DRX890W 500GB. Replaced with DRX890WL (Built in Wi-Fi Lite Box)
Sky +HD DRX895 2TB Replaced with DRX895W (Built in Wi-Fi)
Sky +HD DRX895 1.5TB replaced with 2TB model
Sky +HD DRX890 500GB Replaced with DRX890W (Built in Wi-Fi)
Wardy46UK
Thanks for info
Colin
On average, new discussions are replied to by our users within 100 minutes
