29 Sep 2023 02:20 PM
The sky listings is only showing till midnight. There is nothing for Saturday onwards. Any idea how l can fix this
29 Sep 2023 02:23 PM
Posted by a Superuser, not a Sky employee. Find out moreCheck your signal strengths: Services > Settings > Signal
The white part of all 4 bars should be half way across.
29 Sep 2023 02:24 PM
Done that already. Switched it on and off as well
29 Sep 2023 02:25 PM
Posted by a Superuser, not a Sky employee. Find out moreIt would have been helpful to say so. What else have you tried?
29 Sep 2023 02:26 PM
Only input 1 strength and quality is showing as full
input 2 blank
29 Sep 2023 02:29 PM
Posted by a Superuser, not a Sky employee. Find out moreThat's the reason, then. You have no signal from the dish (or communal system) on dish input 2.
If it's your own dish, you'll need to book a local satellite installer to take a look unless you have Sky Protect.
If it's a communal dish, speak to your buildings management people.
On average, new discussions are replied to by our users within 100 minutes
