29 Apr 2023 07:42 AM
I can't watch any of the HD channels any more it just tells me SKY+HD box isn't getting a satellite signal. All other channels are fine. I can't watch BBC 1 BBC2 ITV1 CHANNEL 4 CHANNEL 5. etc. What is going on. Can I fix this myself
29 Apr 2023 08:03 AM
Posted by a Superuser, not a Sky employee. Find out moreThere's a fault with your ,dish setup somewhere.
Turn your Sky box off at the plug and disconnect and reconnect the cables from your dish. Be careful to line up the plug and the socket accurately when you reconnect the dish cables, as it's easy to bend the centre pins of the plugs.
If that doesn't resolve the issue, your best option is to call Sky to book an engineer who will check the setup from end to end.
01 May 2023 02:13 AM
This did not help, I have since paid extra to add HD to all channels hoping this would cure my problem all programs are now in HD . Nothing has changed still can't watch BBC1 HD, BBC TWO HD, ITV1 HD, CHANNEL 4 HD, OR CHANNEL 5 HD all other channels are ok in HD so it can't be the cables or box
01 May 2023 06:09 AM
Posted by a Superuser, not a Sky employee. Find out moreIt could be an issue with your dish so..
01 May 2023 08:15 AM
BBC1, BBC2, ITV, C4, and C5 are provided in HD free of charge.
You'll need to book an engineer to check,your dish setup, as I posted before.
On average, new discussions are replied to by our users within 100 minutes
