27 Jan 2024 11:03 AM
Hi
Ive lost reception on some channels on my Sky+HD box just after the recent high winds.
My first thought was the dish may have moved but photographed from the ground, everything looks OK except for damage you can see at the top of the quad LNBP in the photo.
The light grey piece has broken and possibly allowing rain in?
I've gone through what troubleshooting checks I could make on screen as far as it saying if the Lock Indicator shows as "Not Locked", I need to phone Sky.
Should I just go ahead and replace the defective quad LNBP in any case as it seems to be an obvious defect needing fixed?
Many thanks
27 Jan 2024 11:12 AM
Posted by a Superuser, not a Sky employee. Find out more"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
27 Jan 2024 11:18 AM
Posted by a Superuser, not a Sky employee. Find out more@Candleriggs signal strength and quality on dish input 2 are also below par. It's difficult to see by eye whether or not the dish alignment has been disturbed.
If you're thinking of replacing the LNB yourself it would doubtless be cheaper than calling out a local installer, but obviously is the alignment is off, it won't fix the problem and you'll still need to get someone out.
27 Jan 2024 11:21 AM
@Annie+UK @thanks for the reply.
I have had an offer of a free upgrade and box for SkyQ but I need an "aerial out" ( probably not the right terminology) connection and a SkyQ box doesn't have one.
I did contact one installer who replied that I should contact Sky first, but now that I have seen an obvious physical defect on the LNB I wondered if I should just try again and get an engineer out to replace it. Do I have to go through Sky to do that? Is replacing the defective part something I could do myself?
27 Jan 2024 11:23 AM
Posted by a Superuser, not a Sky employee. Find out more27 Jan 2024 11:25 AM
@Mark39 thanks.
That light grey piece looks like it may just be a protective cap. Is it and can it be replaced? Are there any diagrams of what's below it available online?
27 Jan 2024 12:00 PM
Why do you need an aerial out on the box?
27 Jan 2024 12:18 PM
@Exiled-in-HH @we have two other tvs, one in a room which is about sixty feet away from the room with the Sky+HD box in it and I use a cable from the aerial out to share the signal to both those tvs. It does mean that the second tv has to watch the same programmes as the first one is tuned to, but that's ok. On the third tv, I can either watch whatever the Sky+HD box is tuned to or watch something different on Freesat. We couldn't make a similar connection via broadband as ours is not good enough. 14mbps on a good day.
27 Jan 2024 12:31 PM
Posted by a Superuser, not a Sky employee. Find out moreSyk Q has mini boxes that link extra TVs wirelessly on your internal network you don't need to use a coax cable that gives lower quality output
27 Jan 2024 12:36 PM - last edited: 27 Jan 2024 01:24 PM
You don't need an aerial out to watch DTT🤔
Do you really want to watch very low quality SD output by a Sky box?
You can connect Sky Q boxes and Sky Q minis using powerline networking ... running Ethernet cables isn't necessary😉
27 Jan 2024 01:09 PM
@Exiled-in-HH @Annie+UK our Internet isn't great. As I said 14mbps is on a good day. I wouldn't like to have to rely on it for tv. I'd imagine there'd be a lot of buffering going on. Also we're spending almost£90 a month so I don't really want to have to pay out even more.
27 Jan 2024 01:13 PM
Posted by a Superuser, not a Sky employee. Find out moreNot all content is streamed some is downloaded to the harddrive so does not suffer from buffering, the connection between a Sky Q main box and a Sky Q mini to view recordings and live TV is through your router only and not the Internet so the broadband speed is irrelevant for this
27 Jan 2024 01:20 PM
The 14 Mbps BB you get would deliver far superior picture quality than the low quality SD you are distributing from you Sky+ box🤔
27 Jan 2024 01:46 PM
@Candleriggs wrote:
@Mark39 thanks.
Hard to say from the photo. Almost certainly there won't be a spare you can use to replace it.
27 Jan 2024 01:53 PM
Posted by a Superuser, not a Sky employee. Find out more@Candleriggs Sky Q creates its own wireless network between the main box and Mini boxes. It uses that to transmit content, rather than your broadband connection from the main box to the Minis.
Broadband is still used for On Demand downloads, where speed is immaterial since the content is recorded on the main box's hard disk. You might have a problem with the streaming apps hosted on the Sky Q box, but that's not something you might miss, as Sky+ has no apps!
Alternatively, you could consider an HDMI to RF modulator, which you could use to connect to your existing RF cable network between TVs. Not cheap at around £100, but it would be a one-off cost.
On average, new discussions are replied to by our users within 100 minutes
