19 Sep 2023 07:04 PM
Janet Burton, 28 little ings,can be watching sky, keeps going on and off regular. Switch back on and then goes off again in about half an or so. It's being doing this for the last month now!!!!!
19 Sep 2023 07:25 PM
(Resetting the settings will also reset:
Settings changed within the hidden engineer menu, include LNB type. If on a communal dish you need to reset the LNB to SCR in the hidden menu. After changing the LNB type you need to reboot the Q box.)
If the issue continues suggest you contact Sky for an Engineer
21 Sep 2023 06:22 PM
Its not a Q box its a. HD+ box!!!! I have had it years and i have reset and still not keeping goi g off!
21 Sep 2023 06:24 PM
Do you havea phone number so i can contact sky for an engineer, please
21 Sep 2023 06:27 PM
You were posting in the Sky Q forum and so I have moved your thread to the Sky+ forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
On average, new discussions are replied to by our users within 100 minutes
