Discussion topic: Input 1 lock indicator - Not locked. Input 2 is fine. I have almost no channels.
This message was authored by NY1 This message was authored by: NY1
No external signal issues. Dish isnt blocked. From the settings - signal, Input 1 - NOT LOCKED. Network ID - NULL. Input 2 is OK.
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Input 1 lock indicator - Not locked. Input 2 is fine. I have almost no channels.
You need either Sky or a 3rd party installer to take a look and find the fault
This message was authored by oj01 This message was authored by: oj01
@NY1 To begin with, and if you're able, you could carefully swap over the two dish input cables at the back of your box (switch the box off at the plug first). Then see if the problem is either fixed (one of the cables might have been loose) or the problem has moved to Input 2.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Staying on Sky+HD
On average, new discussions are replied to by our users within 100 minutes
