Discussion topic: Help!.
This message was authored by Obi123 This message was authored by: Obi123
Help!.
Hi.
I can't get catch up on my Sky HD box.
and I can't pause, forward  or do anything with ITV channel.
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Help!.
Try a Planner rebuild:
For Sky Plus HD boxes (DRX890/DRX895) with the latest software try the following instructions:
• Press SERVICES on your Sky remote control
• Go to Help
• Select Sky+ Rebuild
• Press SELECT (this will start the rebuild)
If the above does not work try the following (Note: the first 5 steps are better done whilst looking at the remote control as the feedback on screen can be confusing):
• Press 0 (very old boxes may need you to press 4 instead)
• Press 0
• Press 1
• Press SELECT (You should now be in the hidden menu)
• Press 7 (Sky+ Rebuild)
• Press SELECT (An on-screen message will be displayed)
The above and so much more can be found in my Sky Plus F⋅A⋅Q
On average, new discussions are replied to by our users within 100 minutes
