20 Dec 2022 09:30 AM
Posted by a Superuser, not a Sky employee. Find out more20 Dec 2022 09:31 AM
Anne,
Thank you for your amplifier connection, About ten days ago I searched for a line amp. for connecction to the Sky socket. But I left the search for other ideas.
But now I am pursuing this with GD1
20 Dec 2022 09:07 AM
To GD1.
Good clear description-Thank you!
But the Sky receiver has a scart socket. Now in my large box of connectors is a scart plug with a switch audio output connection for me to try with a cord signal to the headphones.
I'll let you know! <<<<<<<<
Regards,
Colin
END
20 Dec 2022 10:02 AM
Annie,
Two weeks ago I sort a line amplifier but then didnt find anything suitable.
But the Sky receiver has a scart socket. Now in my large box of connectors is a scart plug with a switch audio output connection [RCA] for me to try with a cord signal to the headphones.
Thanks for your help,
Colin
20 Dec 2022 11:17 AM - last edited: 20 Dec 2022 11:27 AM
Again, you'd be feeding line output and impedance intended for input to an amplifier directly to headphones instead: this is not how such things are meant to work!
As @Mark39 indicates above, you need to take any audio output extracted from the Sky box through an amplification circuit to get headphones to work unless the headphones themselve are rare beasts with their own amplification (and even then impedance will still be an issue).
20 Dec 2022 04:04 PM
Timmy,
Thank you for your reference regarding an audio output level from a scart socket for the phones. Since posting the intention to take a connection this way - it's been completed this am and the o/p level is clear on the headphones and more-or-less- ok". but, You are correct the volume on the headphones could be somewhat higher.
I now regard this issue of sourcing a satisfactory audio connection as complete.
It just leaves me to thank all for the assistance. This is the first post on the Sky Community for me and clearly it has worked well.
On average, new discussions are replied to by our users within 100 minutes
