13 Mar 2023 11:37 PM
When I go to I player to download a programme if I try to go back to a sky channel tv screen goes blank & I can't access any other channels. I have to unplug sky box & restart. Beginning to wish I hadn't upgraded to Sky Q 🙄
14 Mar 2023 06:03 AM
@Swarb1 wrote:When I go to I player to download a programme if I try to go back to a sky channel tv screen goes blank & I can't access any other channels. I have to unplug sky box & restart. Beginning to wish I hadn't upgraded to Sky Q 🙄
That's not normal.
I tend to use iPlayer on the TV anyway as it's more responsive but not seen this. How are you exiting iPlayer?
14 Mar 2023 11:43 AM
I use the home button or sometimes the back button.
14 Mar 2023 11:59 AM
Posted by a Superuser, not a Sky employee. Find out moreAre you on the latest Q firmware? Q210.blah?
15 Mar 2023 12:22 PM
Sorry , no idea 🤔
15 Mar 2023 12:29 PM
@Swarb1 wrote:
Sorry , no idea 🤔
Hi @Swarb1
You can check your Software version here
When Exiting Sky Q Apps its best to use the Exit Apps option in the App if there is one or if not press Dismiss (left of Home button on Remote) multiple times until you get the leave App option.
18 Sep 2023 10:16 PM
I'm having the same problem. Exiting iPlayer and then going back to sky all the channels are blank or in some bizarre instances the iPlayer still seems to be playing over normal TV. Very frustrating. Any tips to overcome this appreciated.
06 Feb 2024 11:11 PM
I've had the same issue on many occasions if I don't manage to get out of iplayer immediately by pressing the back button repeatedly. I contacted Sky and every time they have fobbed me off with 'You must be using old firmware' they take me through the firmware upgrade - after switching off and unplugging the damned thing once again, then it works. However it's just happened again and I only upgraded the firmware 2 we3ks ago, so that's a crock of Crap. This has to be a known fault with Sky and Iplayer compatibility
07 Feb 2024 12:05 AM - last edited: 07 Feb 2024 12:49 AM
Posted by a Superuser, not a Sky employee. Find out moreNo it's weird. Never have this problem. Just tested it again (on the main Q box) - exited fine when I hit Home.
What hardware version are you on?
