Discussion topic: Tv and sky Q box not connecting
This message was authored by Mavboy This message was authored by: Mavboy
Internet and phone went off for several days, the engineer came to outside property and it came back on at 6.15 last night, but the TV is not connecting with sky Q box so no apps or anyting interative
Re: Tv and sky Q box not connecting
Hi @Mavboy
Try a Network Reset found in Q box Home - Settings - Setup - Network.
