Discussion topic: Starlink
This message was authored by JamesLaff This message was authored by: JamesLaff
Starlink
I have just had starlink internet installed and am having trouble using with my sky boxes!
Re: Starlink
Hi @JamesLaff
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
Wait until the router is completely back and running and then try a Network Reset found in main Q box Home - Settings - Setup - Network.
